tempest
I found an old IBM PS/2 Model 80 tower here at work (says type 8580-111) which makes it a 386 DX. It has a bunch of cards in it that I haven't identified yet:
Going by the names on the cards:
VGA Card with daughter board? Says 75X4439 on it
Two SCSI adapter boards connected to each other by a ribbon cable (one is a Centronics style and one is a 50 pin SCSI 2 style). This is also hooked into the second bay below the disk drive and the the hard drive.
Enhanced 80386 Memory Expansion (has four 2MB sticks of memory in it)
80386 2-8MB Memory Expansion Option (has four 2MB sticks of memory in it)
Dual Asynchronous Adapter
Looks like it has one hard drive in it (a big full height one) and a 1.44MB 3.5" disk drive. The system turns on and says it has 4MB of memory but gives me the following codes on boot:
161
163
These are battery related if I'm not mistaken (I'm sure the battery is looooong dead).
Then the hard drive light goes on and the hard drive makes a clicking noise but that's it. I assume it's dead and the floppy drive lights but doesn't seem to read. I assume it's dead as well. I found a replacement in the junk pile, but I'm not sure if it's good either. How do you get the disk drive out? There's a tab on the bottom of it which makes me think it just slides out, but it's stuck and I can't get the cable off the back of it anyway. Do both sides of the case open? If so I can't see how to open the right side.
Any idea why it would only detect 4MB of RAM? I assume that's what's on the motherboard and it should have 16MB altogether.
Is this thing worth saving? Does it have any value?
161
163
