Smack2k
Trying to setup a 386 PC (Forex FRX/386DX is the name on the boot screen, cant find this actual board online) and having the following issue:
When I hooked things up with just the SCSI controller (Adaptec AHA-1522A) the system boots fine, sees the attached floppy drives and hard drive, and boots from either floppy or hard disk, depending on which I choose. I have a 1 GB SCSI Hard Drive, a 3 1/2", and a 5 1/4" Drive hooked up to the SCSI controller.
When I then install an IDE Controller (so I can hook-up the CD-ROM and Zip Drive) to the system (Goldstar Prime, PT-604A) and set the jumpers to disable the floppy drive, the system will boot up, sees the floppy drives, but wont boot from them, the A: Drive just lights up for about 2 seconds before moving on and the hard drive boots up...I dont have the CD-Rom and Zip hooked up to the controller yet, but the floppy controller is disabled on the card and Hard Drive / IDE Enabled....
I have tried several ISA IDE Controllers and they all do the same thing....disabling the floppy AND Hard Drive from the IDE Controller causes the Floppy Drive to light up and stay lit up, but nothing happens and the system sits there until powered off....
Am I doing something wrong here?? Removing the IDE Controller allows the system to boot up again fine from floppy....I checked all the labeled jumpers on the board to and dont see anything strange.
I also have a Soundblaster 2 Pro and a TSENG ET4000 1 MB Video Card and an ISA NIC Card hooked up to the system.
