ButINeededThatName
So I picked up this machine (along with my sixth Model 95, a 25 286 and a Model 30) for free not too long ago and after a lot of cleaning I've started doing some actual work on them.
Anyways, the issue is the system simply just does not POST. When powering it on both of the fans and the hard disk spin up, the screen flashes and the three lock lights on the keyboards flash, however nothing appears on screen, the diskette drive doesn't do a seek test and no beep codes are emitted. I've noticed that the light on the CD-ROM drive stays lit (it's an IBM CD-ROM II drive) and oddly enough, when you power the system down there is intermittent crackling from the speaker.
I've already tried swapping around MCA cards as well as the processor complex and the SIMMs are all 8Mb parity (8x8Mb), so I'm not sure what else to check at this point. Any pointers would be greatly appreciated.
