Hi all - referred to this board by a member of ArsTechnica - I cross-posted this there:
I have an ancient laptop from the 1990s -- A Compaq Lite 4/33c which traveled with me to the ends of the Earth. The machine is running MS-DOS / Windows 3.1 and has the following hard drive: Seagate st9235ag (ATA) Here is the manual: https://www.seagate.com/support/disc/manuals/ata/9235pmb.pdf
The machine boots up and operates in Windows just fine, but I'm trying to figure out how to get the data off, in the absence of any USB or anything. It has a floppy disk drive that does not work (broken belt); I tried another floppy drive in that port but it was not recognized.
I removed this hard drive and plugged it into a USB interface on my new laptop, but the disk is not recognized, neither by Windows 10 or XP nor Ubuntu 18. It shows up in Windows disk management as 'not initialized.' It fails to initialize with "incorrect function" Changing jumpers on the drive did not seem to have an effect.
Can anyone help me figure out what would be necessary to get this drive recognized? It has 100 megabytes of ancient data of some value to me. In the absence of a working floppy drive, I think I have exhausted hardware options for getting data off with something like a serial to USB adapter, because I can't get Terminal or Kermit on there.
If it's possible to get the drive recognized that would be a big help. Cheers.
