Greetings.
I'm trying to run Windows for Workgroups 3.11 in VirtualBox with a copy of IBM PC DOS 2000, upgraded to the 7.1 version with files from the latest IBM ServerGuide Scripting Toolkit, which date to December 2003.
Much like MS-DOS 7.1 from Win 9x, I get an error that says "Cannot find or load required file KRNL386.EXE." and others, all of which point to needing the same type of patch.
How can I use or modify 3xStart to accept IBM PC DOS and not MS-DOS?
On a lark, I tried to copy and rename the IBM DOS kernel files (IBMBIO.COM and IBMDOS.COM) to IO.SYS to see if 3xStart would accept them, which did not work.
