cptnapalm
Saved from going to a scrap yard and, after having its SBC clock battery replaced, it boots up fine. Curiously, the time defaulted to January 3, 2014; I wonder if that was when the battery died and it stored it in the onboard flash. There are neither disks nor their carriers: the state sanitizes things with hammers. So it'll be emulated storage, if I can get that far (SE software for one).
I dusted much of it off, but to clean it more properly I need to unscrew those socket screws. I can't make out what kind of screw head they are; if you know what the appropriate tool for that is, I'd appreciate it.
How much of the hardware (Camel card excluded) can be pulled and/or replaced (assuming there are OS/2 drivers for the replacements)? Could the SBC PICMG 1.0 card be replaced with another one? Under no foreseeable circumstances will the parallel channel, ESCON or SSA cards ever be useful to me.
While I was able to find the Service Guide Supplement (SY246162), the Service Guide (SY24-6155-02) itself, is the one manual I've searched for to no avail. If anyone has a PDF, I would be grateful for it.
Thank you.
Thank you.
