Hi all, I am in the process of fixing up this NEC PC-8801 that I found locally.
The first issue that I had to fixed was the keyboard not working correctly. When I press any key at all on it, it showed a different character on the screen. Once i pulled the keyboard apart, I found a Faulty 74LS159. Once I replaced it, the keyboard functioned correctly.
The second issue that I am currently is getting a way to load programs onto the computer. Hence why I purchased this NEC 80S31.
So the current issue I am having is getting a HXC Gotek emulator or a Flash Floppy emulator with this unit. If anybody has a idea how i would set it up it would be good.
