Nama
I'm trying to do is run my dual 801 Shugart drives in New Zealand at 60hz.
New Zealand power is typically 50hz, which means my drives spin at 300rpm as opposed to 360rpm. So I was thinking to do the following:
1) NZ Mains 220vac 50Hz into a 12vdc converter (a PC power supply will probably do for this)
2) 12vdc into a '12vdc to 120vac' 60z inverter
3) 120vac at 60z into the Shugart drives.
Is there any problems that could arise from doing this with vintage equipment?
Also, does anyone have know approximately how may Watts a dual Shugart 801 setup will draw?
Just thought I'd ask before going ahead and purchasing an inverter, don't want to waste any money if this direction is problematic.
Cheers
Phil
Cheers
Phil
