T-Squared
I have done it! It took three video cards, but I seem to have found the correct type that outputs proper EGA! Paradise Autoswitch PEGA1A doesn't seem to follow the standard exactly. Now I sort of wish I had kept the Tecmar 480 EGA Master video card I bought...
Instead, what I have in my system is a Twinhead CT-8090 EGA video card, and it seems to work fine! (Though it badly needed a new 32-pin feature connector socket, and some solder-resist touchup beforehand.) I'm a bit disappointed that I can't get the 64-color-palette-based games to work, but I'm glad that EGA works nonetheless!
It's a bit buggy, though. I may have to adjust the intensity pots on the CRT socket harness, because the colors are not as distinct as I'd like them to be. (as you can see on the Space Quest example, I'm certain there's supposed to be a light blue in that logo somewhere.) Something may be funky with the intensity bit. I seem to be having that problem with all of my games too. What would be light yellow seems to be dark yellow (technically brown), so if I'm assuming correctly, all of the other colors seem to be muted as well.
Unfortunately, I also don't have the proper amount of memory to run PCPaint in EGA mode. (241kb, while I have 256kb at the moment with the interim board that I'm using.)
If it comes to it, I may be selling off that Paradise EGA card.
