I'm in the process of restoring a 5160XT with Hercules graphics and all that lovely stuff...
I had a short on the -12V line so replaced all the tantalum caps.
I had only 320K RAM detected - swapped banks 2 and 6 of the AST SixPakPlus that is installed and now 576K detected so faulty chip is now in bank 6, I'll just replace all 9 chips.
Last fault is this 5151 monitor behaving as attached:
I've disassembled and can't see bulging capacitors, or dry solder joints. Didn't go much further as monitor internals give me the willies... If someone knows what might cause this I'd sure appreciate the advice:
https://youtu.be/jPryi-k_XXY
