commodorebob
- Joined
- Jun 30, 2015
- Messages
- 5
I recently picked up a great IBM haul when I get an IBM PC, XT, and 5155 Portable that also came with tons of accessories and cards.
They were all in various states if disrepair and I recently got the 5150 fully operational and almost have it the way I want it.
In the pile of cards are two 8-Bit ISA memory expansion / multi IO cars that I have not been able to find definitive info on.
The one I really want to use in my 5150 is this awesome looking MBI Monte Carlo multi I/O card that looks like it contains 256KB of RAM, an RTC, and Serial / Joystick Ports.
Unfortunately, it does not like to be in the system along with my XT-IDE due to a conflict of some sort. I could probably fix it if I knew how to setup the card.
This particular card is a complete mystery to me, as I have not even been able to find proof of the companies existence while doing my research while not even getting close to an actual manual.
The model number that seems the most relevant is IBMMC101, however there is another model number on the back that is PC00MCC01.
The second card is the Everex PWA-00071 Memory Expansion Card.
I believe this is a 2MB EMS (with 1MB populated) card.
The closest match I was able to find is the MAXI MAGIC EMS EV-165A, which does seem close.
https://th99.infania.net/i/E-H/52637.htm
Here are some detailed images of the cards.
If anyone knows any information on these I would greatly appreciate it.
