jakari
I've been working on this PC XT/286 on and off for a few months (older thread linked below). Yesterday I got it far enough along to boot from floppy a few times - the SETUP utility, a couple DOS versions. Great.
I reconnected the hard disk and reran Setup. Type 2 HDD, no problem. Hard disk doesn't appear to work correctly. Whatever, that's not surprising on its own. Disconnect HDD, I don't need the noise.
Well, now the floppy controller/drive throws a 601 error on boot. It will switch on the drive motor if a disk is loaded, and never turns it off. I swapped drives and cables, same thing.
This is the "second generation" of the Fixed Disk and Diskette Drive Adapter (http://minuszerodegrees.net/5162/cards/5162_cards.htm#fddda_2) so it doesn't have the capacitors known to fail on the first generation.
Anyone have ideas of what else may go wrong with this card?
Failing that, suggestions on 3rd party replacements? I see that the IBM BIOS may throw a 601 if the FDDDA2 isn't installed at all, so there's that wrinkle. I'm having thoughts about the "Super I/O" multifunction ISA cards that went in later clones. That might need a different BIOS.
I'd love to keep this machine all-original IBM but it's not loving me back.
Older thread on this machine, that seems to have resolved itself:
https://www.vcfed.org/forum/forum/g...rror?79259-IBM-PC-XT-286-(5162)-memory-error=
