Skip94
Hi all
Now I have my new 5150 functioning as it should and getting towards where I want it, having built an XT CF and Adlib clone in the last couple weeks, I want to turn my attention towards the MFM HDD and controller it came with.
The hard drive is a "Microscience" HH612 10mb drive and the controller is a WD1002-WX2-F002.
The drive spins up and when the dip switch on the back is set to "exercise" mode, the stepper motor runs back and forth through its range of travel smoothly with no funny noises.
However with the card plugged in, all I get on boot is the drive LED flashing a bit, then 1701 error.
Looking on minuszerodegrees, the 1701 error could be just about anything!
I've tried the simple stuff. All contacts are spotless, the drive is selected correctly on the dip switches, correct cable, reseated the socketed chips on the board etc.
Beyond that, I have no real idea where to start. This is my first time tinkering with MFM stuff, everything else I have done is IDE.
I know that the drive and controller have to be low level formatted together, but as this drive and card seem to gave been used together before, I would assume tgey should be formatted. Trying to open Spinrite gives me something along the lines of "Controller bad, do not use".
I would prefer not to LLF the drive, as it would be nice to see what was on it in terms of software, before wiping it. Also my gut feeling is that the controller is faulty, rather than the drive.
Does anyone have any thoughts on next steps I can take to diagnose the problem? One thought I had was to socket all the 74LS series chips, so they could be tested, but I'd prefer to track down the actual problem, rather than just start yanking chips out.
Sorry for the essay
Cheers
Andrew
Sorry for the essay
Cheers
Andrew
