ropersonline
- Joined
- Jun 17, 2011
- Messages
- 153
It is a relatively rarely-encountered...
Ahem.
"It is a truth greybeardishly acknowledged that a single AT ISA card in possession of maximum dimensions must be the cause of strife."
No, but seriously:
It is a relatively rarely-encountered but potentially significant annoyance to owners of PC/XT-class computers, that when IBM came out with the PC/AT, the ISA cards for those machines were allowed to be taller, by an extra 3/4 of an inch.
This means that some ISA cards—admittedly a minority—that otherwise would fit and work in a PC/XT will not fit in those machines (or clones with like case dimensions). Or at least they won't allow you to put the case cover back on.
I've done some measuring and reading, and I've noticed something:
Many sources, so far as they show the physical dimensions of ISA cards at all, do not mention the card bracket/slot cover, and especially not its size.
The amount by which the narrow bottom end of the slot cover bracket overhangs from the bottom of the edge connector is 3/4 of an inch.
The amount by which an AT card is allowed to be taller than a PC/XT-class ISA card? Also 3/4 of an inch.
So now I'm really wondering: Was the larger size of the AT ISA card a mistake?
Did someone measure from the wrong starting point and/or not communicate their measurements properly until it was too late?
Does anyone have any thought on this – or maybe even know for sure, because you were there?
Ahem.
No, but seriously:
