voidstar78
I can't remember the last time I made a cable - been decades. So pardon I'm a little excited. And it works, 37-pin to 34-pin adapter to the external connector of the floppy disk controller. I couldn't find a supplier of these anywhere.
This is with 2x HxC2001 floppy emulators. I'm using a Molex to 4-pin Y splitter of one of the physical 5.25" drives to power them (presently hanging out the case just to verify that the cabling all works)..
Only thing to remember: if you boot PC-DOS before v3.2, you can only use 360KB disks images or less. v3.2 or later, you can use 720KB images (and the 5150 stock controller won't support over 720K, but the HxC can if you use some newer controller).
Attached is CheckIt 1.10 reporting the drives (along also with the XT-IDE E: drive - and verified they all 4 work without the XT-IDE, or with the XT-IDE then just pushing E on startup let the XT-IDE boot from the CF as E. [CheckIt says XT, but this is really a 5150 later model B configured with the onboard 256KB RAM @ stock 4.77mhz 8088]
If you boot with PC-DOS 2.10 and set the HxC to 720KB images (that 2.10 doesn't support), then you get funny results when doing DIR (see attached).
The cable is kind of easy to make, but you do need a couple parts and tools, so it's not completely trivial. It's a bit late in the day now, but I'll try to post a write up somewhere about it tomorrow (the notes at minueszerodegrees.net are good, but not quite a step-by-step tutorial).
The next thing I want to verify is if I can just use the external drives by themselves -- and if so, do I need to still leave it as 4-drives in the dip settings or can I leave it as 2-drives? What I'm trying to get at is: if someone has a bone stock 5150 model A, and absolutely didn't want to open it - but they wanted a little extra disk space to work with (or couldn't find physical disk media for some software they wanted to try, or didn't have a slot open for an XT-IDE, etc.), then they could just attach an HxC to the external port (but I'm not sure if they can boot from it). You'd still have to open the case at least once, to probably set it to 4 disk drives. Or if you leave it at 2 drives and just remove the internal edge connector, maybe you can boost from the external connections? We'll see, ran out of time today to try. [ but without the case open, then you'd have to find a 4-pin power connector for the external drives - USB to Molex to Berg maybe? ]
And the 63W handles this just fine.
