carlos12
Hi! I'm looking for a VGA card for my 8086 system. The problem is the 8 bit ISA cards seem to be quite scarce. It looks far easier to find and buy a 16 bit card. I read on minuszerodegrees.net that there are some 16 bit ISA card that work on 8 bit slots on 8086/88 systems. I watched this table: http://www.minuszerodegrees.net/5150/vga/5150_vga.htm
But there's a card that is not on that table, the OAK OTI 087X. I read the databook of this card and it says:
"Integrated bus interface for PC/XT/AT and local bus implementation". But on the inside the text only speaks about AT, 286, 386 and 486.
Do you think this one could be used on a 8 bit slot? Can the computer be damaged is finally incompatible?
Thank you so much.
Thank you so much.
