Hi
Trying to get a PS/2 50Z to work. Probably at least two problems.
Symptoms:
If I switch it on with the HD in place the system remains quiescent with no POST codes/beeps or beeps.
If I disconnect the HD it boots but I get a Video failure set of beeps (1 long, 2 short) and then a floppy drive seek, the video looks like this (some bits are flashing):
So, I was thinking:
For the failure to boot, either a weak PSU or just a bad HD which in this case is a Seagate ST-138I 30Mb (ESDI isn't it?)
For the video failure, again maybe a weak PSU or video or video RAM failure?
The system unit has maybe taken some sort of thump at some stage as the rear plastic backplate is cracked around the fan exit and some of the grill is missing. This might have done the HD if so,
Anybody seen anything like this before?
Regards
Interalia
UK
Symptoms:
So, I was thinking:
Regards
Interalia
UK
