Hello everyone,
First post here. I've spent the last week or so getting my old PS/2 Model 60 running. After replacing the battery and the electrolytic capactitors in the floppy drive, it's happily booting from the ESDI fixed disk. (There are still some FDD issues but they probably deserve another thread!)
My issue is currently with the Memory Expansion Adapter that is installed. QBMCA identifies it as an FEFE (IBM 2 MB 16-BIT MEMORY ADAPTER) which matches the information here (it's the first one in that list) and the Reference Disk seems to see it and configure it just fine, saying there is 3072 KB of installed memory. However, the Reference Disk only shows 1024KB of available memory. When booting, I get a 160000 FFFE 201 and a 164 error.
My understanding is that this is a memory size error, accompanied by a memory test failure which says it's the first bit failing at address 0x160000. I've tried reseating the card and all the SIMMs, as well as swapping the SIMMs around and I don't think the address of the error changes. That is a bit of a surprise, and I also expected that if the error was with the card it would show up at just after 1 MB...?
With the card removed and the machine reconfigured from the reference disk, it boots fine with 1 MB of RAM but I was really hoping for the full 3 MB.
As a starting point, I metered all the through-hole and SMT capacitors on the memory expansion card and none are shorted, which I believe is the common failure mode for tantalum capacitors.
Any pointers for next steps, or thoughts that I've missed something stupid?
Cheers
James
Cheers
James
