Let me tell you what I've been doing for the past 3 days. Trying to get a really old Alps RJG2ZA 360k drive to work. Mine also has a belt.
[EDIT: FOR THE PARAGRAPH BELOW I THINK I USED THE WRONG JUMPER SETTINGS ON THE DTK PII-151B. FRANKLY THE DIAGRAM ON THE CARD IS CONFUSING AND CONFLICTS WITH THE ONLINE DOCUMENATION HERE
http://stason.org/TULARC/pc/io-cards/C-D/DTK-COMPUTER-INC-Floppy-drive-controller-PII-151B.html. AFTER RETESTING ON 3 DIFFERENT CONTROLLERS, INCLUDING THE DTK PII-151, WITH BIOS BOTH ENABLED AND DISABLED, WITH SETTING 360K IN A 486 BIOS WHEN THE BIOS IS DISABLED, THEY ALL FAILED. THE THING THAT MAKES THE PII-151B DIFFERENT FROM THE OTHER ONES IS IT HAS JUMPERS TO SET 360K/1.2M/720K/1.44M. ALSO IN ORDER FOR THE ALPS TO WORK I HAD TO SET THE BIOS ENABLED JP5 TO CLOSE. WHEN THE ALPS IS NOT WORKING IT EITHER GIVES THE ERROR "DRIVE NOT READY" OR WILL SEE B: AS A CLONE OF A:]
I was trying to get it to work with an original IBM XT 8mhz. First of all I did not know that this drive does not get auto detected by the floppy controller! I have never seen this in my life. The motherboard detected it as a 720K. It wanted to format disks as 720K! Chkdsk.exe reports it as a 720K after a successful format. When it reached track 41 with "firm.com" it would stop with an error. Then I went and plugged it into a 486 with a VLB controller. The 486 thought that drive b: (alps) was drive a: (1.44) and would only access a:. I also tried everything with the XT motherboard, cables, different controller, swap a: for b:. Nothing.
You know what I had to do to get the damn thing to work? I had to force it with an 8-bit DTK controller that had manual override feature.
It is dtk pII-151B
[EDIT: BELOW I SAY NO MIXING DRIVES ON THIS CONTROLLER. I AM NOT SURE DUE TO STRANGE JUMPER DIAGRAMS.]
I had to set the DTK to 360K with jumpers. Oh and guess what? No mixing drives with this controller. You can't use 1.44M and 360K it has to be both 360K drives. Oh and don't forget to set the jumper to enable the BIOS on the card of course. Set the controller for single speed if possible. I also set data precompensation mode to the slowest transfer rate setting (JP2 = 1-2). On the XT motherboard set dip7 and dip8 to see no drives at all (since the DTK BIOS does it). Also don't think it will read your floppies formatted with a 1.2M drive nooooooo. Then you have track widths that are too thin. You will need to image the floppy with "firm.com"
http://www.glennmcc.org/download/free_software/disk1.htm#floppyutil from another drive and then reimage it with firm.com on any 360K or the alps to get a nice fat track width. I mean this is really old equipment man!
Oh and that belt? It reads "405" on it. But that probabily doesn't help.
This Alps drive I have looks positively trippy! The front door looks just like commodore 1541 drive exactly! The noise it makes sounds like static electricity. A great find! I hope you get it working. Maybe your Alps has autodetect and has newer features than mine? Somehow because it has a belt I doubt it. I could be wrong.
One more thing. The jumpers on the drive itself. The only jumper you should need is DS2 *I THINK*. Here is a guide to what the jumpers mean for old 360k drives
http://www.classiccmp.org/pipermail/cctalk/1999-March/122818.html
I just remembered one last thing to help you, I know this is getting crazy. When I tried to get the DTK to work in the 486 board (newer model) it did not work. I might have been able to get it working by setting the 8 bit I/O recovery setting in the BIOS higher but I didn't bother since I planned to use this drive in an XT. They have this setting in fast machines that still had ISA bus. Therefore if you still have a Pentium or Pentium 2 with ISA bus and you bought a special controller like this DTK it is *possible* it could work. If you really must be able to read 360k drives in your latest computer you might need a newer one like panasonic/matsushita and even then you might need to boot into dos, freedos or windows 98 lite, etc, etc in order to have 100% support.
Also you might be able to use a catweasel like that guy said.
Thank you and have an Alps-y nice day.
