Minerva10210
Howdy guys
So I was fiddling with my old machines over the weekend - cleaned them all up properly, stripped everything to the bare chassis used a paintbrush to clean everything and some soap on the chassis covers etc.
Now I have a few different ideas here of what I can do with the machines. I would like your guys' input here though.
Now before I note the mods I would like to do, I don't want to do any physical modifications to the machines in such a way that would make it impossible to get the machines back to OEM standards.
First thing I was thinking of doing is to put a vanilla 386 motherboard in the 5155. I would like to be able run win311 on the machine. The issue here is that the CGA (I think ) graphics card in the 5155 is obviously a 8-bit card, but it has an "overhang" that makes it impossible to install this card in a 16-bit slot. Now looking at the card in the 5160, it does not have the overhang, so it will fit. Now the issue with going this route, I am not too sure if the internal monitor will work off the card in the 5160.
On the 5155 card, there is a 4-pin connector (pin 3 blanked) that connects to the monitor internally. On the 5160 card there is a 6-pin connector that looks simmilar, but it does not have a blank pin so I am a bit scared of trying to connect the monitor to this. Alternatively, are there any other GFX cards that I could use that will be able to connect to the monitor in the 5155? Any ideas here?
The other idea that I had is to get something like a ST-251 1/2 height HDD to put into the 5155. I can't remember how to configure MFM HDD's though, any resources available that I can read up on?
Then another thing here. The 5155 has a 10MHz AMD based CPU in it, the 5160 has a 4.77MHz Intel based CPU. Is it possible that if I get hold of another 10MHz CPU just to retrofit the CPU, or is it necessary for other changes that have to be made?
Also, is there a real world difference between the 8088 and the 8086? I noted that the 86 has a 16bit bus vs the 88 has a 8bit bus. As I asked does this make a real world difference?
Phew! I think that is all for now!
Thanks guys!
Jonathan
ZA
Thanks guys!
Jonathan
ZA
