Rick Ethridge
Did any IBM compatibles ever use four floppy drives? Can newer PC's use a secondary floppy controller for four floppy drives?
Mad-Mike said:Actually, most modern motherboards I come across only seem to support ONE floppy drive. The newest board I have ever had that supported 2 MFM Floppy type devices was a Pentium Pro board, everything else so far won't take 2 drives, except maybe if you put in an aftermarket controller.
mbbrutman said:The original diskette controller in the IBM PC supported two driver on the internal chain and two drives on the external chain.
mbbrutman said:The original IBM PC did have a four floppy controller.
There was an internal connector that supported two internal drives. There was the 37 pin external cable for two external drives.
paul said:Funny that there are four DS (drive select) lines on each controller cable and disk drive, yet only two or three are used. The Compaq DeskPro 386 that I used to have had support for (3) floppy drives right off the same cable. I think there was a device driver for the third, so it had a configurable drive letter.
And (off topic,) that Compaq also had the first IDE interface that I was aware of, even though it was not called that at the time.
Mad-Mike said:As for IDE, I think the later Deskpro 386/16 (REV 2 motherboard) and Deskpro 286/12 came with it standard, usually with a quasi-proprietary 30,40, 60, 80, or 160 MB hard disk drive. On my old Deskpro 386/16 I sold before moving to another state, it had a panel inside that marked the IDE controller card as an "ESDI/ST-506 controller card" in the diagram, so it may have very well been the first. But I don't know for sure.
Mad-Mike said:paul said:Funny that there are four DS (drive select) lines on each controller cable and disk drive, yet only two or three are used. The Compaq DeskPro 386 that I used to have had support for (3) floppy drives right off the same cable. I think there was a device driver for the third, so it had a configurable drive letter.
The 3rd connection on the Compaq Deskpro 386's floppy connector was probably for the tape backup unit that hardly anyone bought. I've noticed that most of the tape backup units of that era (1986-onward) seem to all be mfm devices that usually plug into the floppy drive cable.
Terry Yager said:I remember having a few Colorado tape drives that ran off the floppy drive connector. They usually came with an appropriate cable that tied-in to the floppy controller.
--T
Terry Yager said:Yes. I've used DAT tape drives too, with a capacity of about 2Mb per drive.
--T
