Hi,
I acquired this motherboard from eBay, a Turbo XT with a 8088-2 processor and 512 kb ram:
Click to enlarge
It runs at 4.77 MHz by default, but switches supposedly to 8 Mhz Turbo mode with a "Ctrl Alt -" key combination (there is a 24 MHz TTL oscillator in the board).
The design seems similar to other Taiwanese XT clone boards, but this has 3 PAL ICs: one is at bottom center near the RAM sockets and the other two are located in the left, between the two Crystal oscillators. From one of these two PALs there are two wires soldered in the bottom side that also enable Turbo mode when shorted.
The problem is that benchmark results report slower clock rates or less performance than expected (Checkit for example says that the 8088 is running at 6 MHz). Without turbo engaged the performance is the expected at 4.77 MHz.
I have tried different bioses with the same result.
Any idea or advice to discover how is wrong?
Click to enlarge
