redhawk579
i plugged in the computer to find the psu was bad so I replaced it and tried again I then blew c56, then blew cs8 if anybody could help I would appreciate it
Do you literaly mean ALL capacitors, or did you mean tantalum capacitors? I suspect that you meant the latter. There is always going to be the possibility that you replace the two tantalum capacitors now only to find that others fail later. I've acquired 5150/5160 motherboards that had one tantalum capacitor fail, and in their many hours of operation afterwards, nothing else has failed. So I suggest that you only replace only the two ones that have failed.do you think i should go and replace all the capacitors or just the ones that went
To maintain the same look-and-feel, I suggest tantalum.if so do I replace them with tantalum capacitors (which are the ones that went or do you think I should use ceramic capacitors.
C1 is adjustable and known as "color adjust" (and other names). It is used to fine tune the colours that appear on a connected composite monitor or TV.also do you know what c1 does
The 5160 Technical Reference is available via links at http://members.dodo.com.au/~slappanel555/51xx_manuals.htmGot a link to a schematic. I can't find mine:-(
