Hard drive for IBM PS/2 Model 25
aitopes
Hello!
Some time ago I bought two IBM PS/2 Model 25 new. The machines had never been used, and even had the security seal placed source.
These computers have BASIC in ROM but no hard drive. I would put a hard disk, but not that kind of record I need.
Anybody can tell me what type of hard drive I can put on an IBM PS 2 Model 25?
Thanks!
PS: Attached are some photos.
You can put in anything that connects to an ISA card, but I imagine you want the original drive...bad news, they are totally proprietary (to the Model 25 and 30, and their submodels). Maybe someone can speak up with the models/part numbers (I believe there are only 2 or 3).
Very nice machines...cool stuff.
Yes, cool pictures. They really are dinky machines aren't they :)
That's one thing I like about the PS/2 range: their unusual designs compared to the run of the mill PC-Clones of the era which tended to mimic the XT or AT in case design.
Tez
God news! :)
I have one 8 bits ISA card and one IDE 107MB hard disk. I try it, thanks .
Yes! Are NEW computers. New, in box ;)
Tez
Yes. Are good machines. Pretty and solid old machines :)
I think you might be better off ordering the ZIP drive support program for 8088 / 8086 computers, and using a ZIP drive as a hard drive.
I have a PS/2 Model 25, but I'm about to send it to a new home.
Thanks!
If your hard disk fails, I'll try it with a ZIP drive.
I guess feeding the puck is going to be a "problem", but I can take 12V and 5V from some of the wires from the power supply.
Thank you all!
If you've any problems with the 8-bit ISA and/or IDE drive, you can always build yourself an XT-IDE and run a CF card for a hard drive. It's a little more expensive than using PalmZIP (assuming that you already have the ZIP drive), but it would allow you to keep the machine looking as if it's original.
Ah, yes, I should have mentioned this about power...if you are confident enough in yourself to make an adapter:
Let me know if you have any issues.
