Great Hierophant
What could you do if you had the money to buy all IBM parts at your disposal and had to build the ultimate 5150? Here is how I would do it :
5150 System Unit w/256KB RAM, 10/27/82 BIOS & BASIC. Math Co-Processor Option, 65W Power Supply
83-Key Keyboard
Slots :
1 - Diskette Drive Adapter w/2x Double Sided Diskette Drives & 4865 Personal Computer 3.5" External Diskette Drive Model 1
2 - Color/Graphics Monitor Adapter w/ 5153 Color Display
3 - 256K Memory Expansion Option
4 - 64K/256K Memory Expansion Option w/128K
5 - Extender Card
5161 PC Expansion Unit w/ 130W Power Supply
Slots :
1 - Fixed Disk Drive Adapter w/2x 10MB Fixed Disk Drives
2 - Asynchronous Communications Adapter
3 - Asynchronous Communications Adapter*
4 - Game Control Adapter
5 - Printer Adapter
6 - Monochrome Display and Printer Adapter w/ 5151 Monochrome Display & 5152 Graphics Printer
7 - Music Feature w/MIDI adapter Unit
8 - Receiver Card
IBM PC-DOS 3.2
* - You could put a substitute a second Music Feature Card here. Of all the options, I am only uncertain whether the Music Feature can be installed in an Expansion Unit. Of course, if you are driving two music cards, there may not be much CPU time left for much else. Since the Music Feature requires an IRQ between 2-7, eliminating an Async adapter solves the problem. Eliminating a printer adapter does not.
My primary concern is use. Every card, every drive, should have some kind of purpose in the machine. IBM made lots of stuff that simply had no real use for a home PC user. But two graphics displays are useful, especially using one for DOS and the other for programs and games. Two Async adapters can support a mouse and a modem/null-modem (I do not believe IBM marketed external modems). Two printers, one for the quick stuff (Graphics Printer) and one for more professional quality (like a Proprinter XL) would not have been unheard of.
As far using an Enhanced Graphics Adapter or Professional Graphics Controller (in the 5161), I feel that they are a much better fit in an AT machine. The PC is rather slow to be driving those high resolutions and color modes.
Finally, I have limited the hardware to items available from IBM before the PC's discontinuance on April 2, 1987. So the Music Feature card is okay, but the PS/2 Display Adapter or the IBM ISA Ethernet adapters of the 1990s are not.
83-Key Keyboard
Slots :
5 - Extender Card
Slots :
5 - Printer Adapter
8 - Receiver Card
IBM PC-DOS 3.2
