Great Hierophant
The monitor in question is an IBM 5153 Color Display, the standard for digital RGBI monitors. This display has a 13" viewable tube. On the back of the monitor, there is a control for vertical size and vertical hold. No other controls are present externally that will change the picture size or position. If the horizontal size is fixed, what should the vertical size be? I would say that the picture size should be proportional to the 4:3 screen dimensions. An active picture on my 5153 measures 9.5625", which I derived using a paper tape measure from IKEA. As that is the long measurement, the short measurement must be 3/4 of that, or 7.1718. So, I adjusted my vertical size knob until I got a active display of roughly that height and I was done.
