An idea I've had for a while now but been unable to test, due to i don't have a 486 currently... Has anyone here tried using one of the smaller cheap 8gb SSD hard drives with a SATA-to-IDE adapter and then using them on a 486 class computer? Or perhaps some of the smaller DOM (Disk-On-Module) things I see on ebay that have an IDE interface and just plug into the connector on the motherboard/controller.
Mainly I'm wondering.. Does it even work at all? I'd assume you'd have to rely on the motherboard's bios auto-detecting it as most ssd/DOM drives don't have C/H/S information printed on them.... I saw one of the 8gb SSD's on newegg last week for $40, and some of the DOM modules are on eBay for $25 - $30, so it might not be such an expensive test, really.
And if anyone did get it working... is there any speed advantage vs mechanical hard drives in these machines?
I have a few older computers:
- A Dell 325P, 386 DX-25 that has a Cyrix 486 DLC-40 chip on it (runs at about 486 DX-25 speed when I enable the software cache) that runs DOS 5.0 (for 1989-1997 games)
- An Acer Altos 1000 Dual Pentium 233 mini-server (mid-tower) that runs Windows 98 (for 1998-2003 games).
In both of these computers, I have SSDs. The Dell 386 has a DOM installed... I can't remember the size, I think it's a 512mb. Because the BIOS and operating system cannot support anything larger than that, I was forced to look for a DOM that was 512mb or smaller. I found one on eBay for $20 something... and have been using it ever since. Quite frankly, the only reason why I did this was for reliability, performance, cost, and cooling.
Reliability - Any hard drive that you purchase now that's 512mb or less, is going to be used, and have a lot of hours on it. A 512mb DOM is going to have no hours on it.
Performance - The speed of the DOM is limited by the throughput of the IDE controller and the limitations of the processor's ability to handle that speed. I can't remember what it is... but it's less than SATA-1 speeds. I would say it's nominally better than a decent hard drive in something like a 386, because it can't really handle any faster speeds.
Cost - If you've looked on eBay at the cost of some of these older hard drives, the costs are insane. I paid almost $100 bucks for a barely used Seagate ST3144a. This DOM was $20 bucks, shipped.
Cooling - It generates almost no heat at all... unlike a hard drive. This doesn't make a huge difference really... but it was worth mentioning.
For configuration... it's not hard. Typically, the DOM will already have a set of specifications... cyls, heads, sectors... and you just enter that in.
Anyway, I use a 2-gig DOM SSD on my P2, and it flies... again, only about the speed of SATA1 (or PATA I should say). I dunno... 150mb/s?
Definitely worth it though. It's a no-brainer for me.
In my 8088... when I get it done. I'm still going to have a Seagate ST-225 RLL hard drive in there... and I'm going to have it "power on" when I turn the computer on. But all the data storage will be on a 128mb DOM. The sound from the Seagate ST-225 is unmistakable... so I have to keep that.
