Defiant1Dave
OK...... Let's get semi-serious about building a REAL expansion unit for the 5140..... with a proper HDD and a few expansion slots.
I've done a little research into the 5140's expansion bus connector. As expected, it IS an 8-bit ISA architecture, and contrary to what one website states, it is NOT a multiplexed 16-bit ISA bus. That being the case, it should be relatively easy to construct a TRUE 5140 Expansion unit, instead of relying upon Interlnk Servers.
So here's what I'm thinking- a free standing box with an 8-bit riser..... maybe 5 slots..... and it's own power supply. Then there'd be a little adapter of some sort, matching the ISA riser to the 72 port edge connector. Finally, there'd be an edge connector male / edge connector female cable going from the expansion unit to the computer itself.
In the FIRST slot, I'd put a Hardcard 20 or 40 which should talk to the ISA bus and 5140 just fine, since it has it's own BIOS...... thus eliminating the need to modify the 5140's bios. (maybe)
To make this happen, I need some data: Specifically, I need the pin-outs for the 72 connection edge-connector on the rear of the 5140.
I ALSO need a few bits of hardware..... parts and pieces:
1. any dead 5140 expansion modules that I can steal the edge connectors from
2. an 8-bit riser card........ OR a plain16-bit one, without any circuitry.
3. a Cool Cabinet to put it all in
4. any 8-bit cards that might play well with the 5140..... especially any 8-bit game ports, I/O ports, or memory cards.
So..... that's my shopping list. I'm accepting donations to the cause in the form of of information and hardware. In return, I'll post my design, successes, rants, and failures right here so that everyone can build their own units..... and/or get a good laugh at such an absurd undertaking!
