The resolution of the photo is very poor, but good enough to determine that the board is not an IBM XT motherboard. It is probably one of many clones of the IBM XT motherboard. The block diagram of the clone motherboard should be the same as (or very close to) the block diagram for the IBM XT motherboard. That block diagram can be found on page XVII (PDF page 19) of the IBM document at http://www.minuszerodegrees.net/manuals/IBM_5155_5160_Technical_Reference_6280089_MAR86.pdfI have this 1988 IBM PC/XT motherboard attached below. Can someone please tell me how can I get the block diagram of this motherboard.
Sounds suspiciously like homework.It's a bit urgent
I'm curious. What was the exercise, how to use Google, or how to use a forum?thanks very much for you help! ...and yes it's a homework exercise about motherboards.
Regards Diego.
Personally I'm interested in the question too, but not in a negative way...
Usually when you see them like that they were used with a riser (or two) to mount the cards sideways for shorter cases. A few makers (like Packard Hell) used the same boards (making one type of board cheaper than two) and just populated them different depending on which case they were going into.I'm interested in why there is only two I/O bus connections populated on the motherboard...
Here it is in higher res:The resolution of the photo is very poor, but good enough to determine that the board is not an IBM XT motherboard. It Sounds suspiciously like homework.
So is the missing 4th. memory bank.
It could only be a 1 MB board if it had sockets for a 4th. bank.It could be a 1 MB board with 768K installed.
LONDON - IBM reportedly told Computoprocessing Ltd., maker of the Compro 88 PC Clone, that the Compro 88's basic input/output system (BIOS) contains a substantial part of the IBM PC's BIOS and thus is in violation of IBM's copyrights...
Ya', looks like a case of too much firmware and not enough hardware in this item! :smile:LONDON - IBM reportedly told Computoprocessing Ltd., maker of the Compro 88 PC Clone, that the Compro 88's basic input/output system (BIOS) contains a substantial part of the IBM PC's BIOS and thus is in violation of IBM's copyrights...
So you want to buy a new PC - a new IBM PC clone has been launched by a UK firm, Computoprocessing (ComPro). The 640K ComPro 88 costs £995, and claims to function exactly like an IBM machine but at a much reduced cost.
Micros here are very expensive. Beeb with printer would be between $NZ1800-3000 (£800-1200). So I use a Burroughs mainframe
It may have been a budget board model, although the inclusion of a V20, sockets for virtually every chip and two crystals would suggest otherwise.
It may have 640K if the first bank had 512kx1 and the second and third banks at 64kx1 chips.
