I dont have found any website on the web dedicated entirely to the ibm ps/1.
I believe that what make different and unique the ps/1 is the 4 quadrant screen and his monitor with power supply inside.
This is why the ps/1 is different from others computers like a common ps/2.
A different hardware and a very good shape and look.
It is not possible to connect an IDE hard disk to a stock IBM PS/1 model 2011, you need the Adapter Card Unit (ACU) expansion to usa ISA cards, but I have never seen one.
If you need an IDE hard disk, you should look for a IBM PS/1 model 2121, it has a 386SX and IDE onboard, but looks like the 286 PS/1.
Yes, the CPU needs a power supply of over 32 volts, 1A minimumBut,we can build an adaptor to use the ps/1 without his monitor?
I upgraded the processor to a cyrix 486 sx 20 mhz and added 4 mb ram
