Techcollect
Hello all,
I just picked up a 5150/5151/5161 combination at a local estate and I'm working on getting this set reactivated.
The 5150 from late 1983 has a 16-64 kB mobo with 64 kB and the 10/27/82 BIOS, MDA, floppy controller and a 64-256 kB memory expansion card with 256 kB.
After a bit of cleaning and checking the settings of jumpers and switches, I fired it up, no POST errors, but the memory count only showed:
62940 Bytes free
Which is less than the 64 kB onboard.
I took all cards except MDA out, deactivated the floppies, set the switches to 64 kB only and the count went to:
61404 Bytes free
Again less than 64 kB.
Does BASIC use part of the RAM for something?
I then put the expansion card back, checked different jumper configurations (here some POST errors occured), but with proper settings (IBM_5150_Guide_tperations_6322510_APR84) and a working BASIC the count remains at 62940 Bytes.
I don't have a diagnostics floppy yet (5,25" drive not yet installed on the XP machine), but maybe someone out there has a clue...
Thank you.
Chris
62940 Bytes free
61404 Bytes free
Thank you.
Chris
