reenigne
Continued from the 8088 prefetch algorithm thread (which was getting a bit off topic).
Yes, exactly - this is for analyzing the execution of some specific pieces of code for a particular set of experiments, rather than being a general ISA bus analysis device - it's not as multi-purpose as other analyzers.
I just noticed that that can do 32 channels (I was thinking it could only do 16, which would make the experiments I wanted to rather fiddly). With 32 it would be possible to monitor most of the CPU signals, which would probably be enough for what I want to do. Still I suspect that having gotten this far, it'd be easier to do it with the board that I've designed. That's a good backup plan though if I can't get this one to work.
Yes, it's definitely a fun little project if nothing else!
Of course any access to a BIOS interrupt or video RAM would disturb the sequence. I understand it would be for a very specific use case you have in mind for your own code so that can be controlled.
I just don't understand the effort to achieve the result you want over picking up a $50 OBLS like westveld suggests.
Keep hacking though. It's what makes all this great.
