wesleyfurr
As I mentioned in another thread, I'm working to get some of my old goodies out of the corners and get them up and running for a "show" the end of the month at a local retirement community. Among the items I want to show is of course my PC model 5150. I dug out a 5151 monitor and it worked (whew), turned it all on and I was grinning from ear to ear when it suddenly just powered off.
Started through troubleshooting and guessed perhaps it was the power supply...so I dug out an old clone machine (case essentially identical to the PC's and XT's)and swapped its power supply into the PC. Powered it on, fan spun, and I was promptly rewarded with a super-mini fireworks display, complete with smoke and all. Crap... Looked closer and found that the capacitor in the corner near the power supply connector and blown its lid. I tried the PC power supply attached the clone motherboard (which actually I had put in a 486DLC board years ago) and it fired up...ok, so PS is good. Put it back in the PC, and it fires up and works beautifully.
So...my question now...how critical is it that I actually replace that capacitor? Pretty comfortably my solder skills are up to snuff to do such a task, but on the other hand, why risk damaging things worse if it will work OK as-is? Same question about an old CGA/mono video card I have here with a blown cap...someone said just snip it off and don't worry about it (haven't tried that yet)...but is it OK to run without one?
I did a quick ebay search for replacement tantalum caps and have put in an order for 10 of them (16v 10uf) at a cost of like $2.50 or something...but of course now I'm concerned I didn't get the right thing...are all tantalum caps "polarized"? I'm not seeing anything in the listing photo indicating polarity...but it's also hard to tell. Item # 220653775284 for anyone who wants to take a look. Also, the PC motherboard uses the odd 3-legged capacitors, which I understand can be replaced with a 2-legged on as long as the center leg has the correct polarity. Any "gotchas" I need to watch out for? Assuming it really does need to be replaced?
Thanks in advance,
Wesley
Thanks in advance,
Wesley
