The power supply in my old 5150 was dying. From time to time the PC was shutting down by itself. I decided to replace the psu with a new one. I checked out the new one had the -5v supply. Then i wired the 20 atx connector to two p8 and p9 connectors. I tested then with a meter and every voltage was correct and in place. I had my doubts about two pins: the power good and the power select. According to what i have read power good pin must be at 5v when everything is already ok. However some people claim there are power supplies that do not provide this functionality. As with regards to power select pin i bridged it to gnd. I checked for two times every pin with a meter without the p8 and p9 connected. All ok.
Then i connected p8 and p9 to the motherboard. Then it was time to press the red big lever. I was nervous.
Red lever to the ON position and a zap sound of dead came out of the power supply. Right away i placed the lever on the off position again. A smoke smelling came from somewhere in the inners of the pc.
I suppose now i have a defunct pc. Ok, i will bury it with honors.
However, my big question is: Why?
What happened ? What was wrong? Was anything missing? Is it related to the power good pin or perhaps to the power select that i bridged? I accept the dead of my beloved IBM PC but I want to know why he dead?
Thank you for your condolences.
