lyonadmiral
I'm just curious to see what is the most performance intensive thing that you have done either on your 5150 or 5160, without the use of accelerator cards or upgrade boards?
Would a V20 be acceptable?
One thing that comes to mind immediately for me is "8088 Corruption' -- requires a soundblaster card, but otherwise leverages a stock 5150 to do something truly amazing for the hardware -- full screen video playback.
My own Pac Man port actually rubs up against the hardware limits, and has a lot of snow on a real CGA (there just isn't enough CPU time left over to add anti-snow code to it) -- but remains playable even on the much slower PC Jr. (which lacks the snow problem).
http://www.deathshadow.com/pakuPaku
I love using the undocumented semi-graphics mode, because it is way 'out of spec' for the hardware.
I guess I'm wondering what you're getting at. Why would you want to do something unusual, and what would that be?
People did spread sheets, word processing, accounting, and that sort of thing. Those with more serious computing needs would likely use more serious computers, or rent services - just like nowadays.
On the other hand, Jim, it might be fun to emulate an 80286 on an 8088, paging from the hard disk. You could start the boot process in the morning and be greeted by the Windows display by the time you got home from work...
Never underestimate the power of a Turing-complete architecture.
- The bad news: No version of windows will "recompile into machine code" and work on an 8088.
- The good news: (...) Geoworks Ensemble,
