gobabushka
Ok, so after a lot of googling, I found out that the power supply board is a-ok. So the issue must be in the motherboard. I have stripped the machine down to the bare minimum. (no sidecars, no floppy or controller, no memory expansion, etc.) But all I get is a white screen with the buzz noise on the monitor. Where should I start checking? Thanks!
and how do I remove the floppy tray WITHOUT breaking the tabs?
