evildragon
Is it possible to make DOS boot up with it's prompt already on the insert mode, so I don't have to hit insert everytime? Also if so, can it be made to stay on? I noticed whenever i type a command, insert is back off.
Only problem with that is you have to be using a version of DOS that supports DOSKEY. Otherwise you could use the standalone Enhanced DOSKEY.One way to do it is to use DOSKEY with the /INSERT switch, but that takes precious conventional memory. There are some 3rd party utilities or shells that may do it as well.
I'm curious why you want insert mode enabled at boot? Also could there be a simple poke (should be) that would do the trick?
