8 bit PC/104 cards to spare?
I would be interested in making an offer if anyone has any to spare?
SCSI
RS232
FDC
RTC
ETHERNET
ETC
Just curious, why do you specifically want 8-bit PC/104 cards? Do you have an existing system with only an 8-bit PC/104 interface that you want to or need to continue using instead of replacing it with something else?
I have some Ampro PC/104 boards that I newer got around to doing much with. I forget how much I paid for these.
http://www.vintage-computer.com/vcforum/showthread.php?29309
I have two three board stacks of boards as pictured in the other thread.
One stack has the CoreModule/486 A60687, MiniModule/FSS A60665 (Floppy/Serial/SCSI), and MiniModule/VGA A60666.
The other stack has the CoreModule/486 A60687, MiniModule/FSI A60676 (Floppy/Serial/IDE), and MiniModule/VGA A60666.
I never found a manual for the CoreModule/486. Here is the manual for the newer but similar CoreModule/486-II
http://web.archive.org/web/19981201051321/http://www.ampro.com/techman/coremodule/5000851.pdf
The original has a 25MHz CX486SLC2 and one serial port versus the 50MHz CX486SLC2-50 and two serial ports. The CoreModule/486 boards I have both have a total of 4MB of RAM.
I think I paid around $40 total last year for both of these three cards stacks, plus spent a couple of $ to build keyboard and VGA cables. They use standard IDE/SCSI/Floppy cables, and standard 10-pin header to DB9 serial cables, and run off single +5V supplies (excluding drives).
These are fairly small and light but I have no idea what it would cost to ship to you.
-Glen
