Hi! Is there a way to add a 1.44 Mb floppy drive to an 8088 PC XT that has internal cabling for 5.25 360 Kb floppy drive? Thanks!
I use a MicroSolutions Backpack drive I bought from a member here in the forums. It connects via parallel port, and allows my to keep both of my full height 5.25" floppy drives installed in the main PC, and I didn't have to lose a bay needed for another drive, like a full height hard disc, that most XT's came out with. I know a lot of XT owners, who have replaced their full height floppy and hard disc drives, with half height ones, but as user, Someguy, and others have reiterated, they don't have a full 1.44 MB 3.5" drive without getting a higher density controller. My installation however; with my Backpack drive connected via parallel port, I didn't have to use an internal drive bay, and kept all 4 of my PC's full height bays; two full height hard discs in the IBM 5161 expansion unit plus the two full height floppy drives in the main PC.
Here's a link to a brand new one on E-Bay that is selling for $39.95. But in all reality, you could possibly find one for far less. Mine, for instance, was a used drive, and I paid only $10.00 including a 5.25, and 3.5" install floppy. The new ones don't come with 5.25" install floppy discs though. I can send you an install floppy if you decide to go this rout. BTW, MicroSolutions also makes/made CD-ROM Backpack drives, CD-reader/re-writable drives, but anything writable will not work with the older PC/XT, and clones. They even have a tape drive that works with the older PC/XT's and compatibles.
The floppy and CD-ROM drives work great with my 5150 system. Although you can typically only have one or the other installed at any given time. I have my system set up so that the drives don't automatically load at startup, and will only run when I run the command for which drive I prefer. It did take some playing, but I got it to work with both floppy, and CD-ROM. Personally, I love mine. It just gave me so much more freedom to move files, and programs to and from my IBM 5150 PC. Of course, using the CD-ROM to bring stuff to the 5150 systems hard discs was so much easier as well. Its really amazing how just adding a single drive made in the usability of the entire system.
Anyway, here are a couple of links to both a new MicroSolutions Backpack floppy, drive, and a used one. There doesn't seem to be nearly as many on E-Bay as there were only a few weeks ago. Perhaps, if you're willing to go with the backpack option, someone here might be able to sell you one.
New:
http://www.ebay.com/itm/MicroSoluti...=US_Floppy_Zip_Jaz_Drives&hash=item3f1ebd95d8
Used: (I don't like this one because its missing the faceplate.
http://www.ebay.com/itm/MicroSoluti...=US_Floppy_Zip_Jaz_Drives&hash=item2335c7fc55
