KLund1
Hi,
I have a Epson HMD-755 hard drive that when it is powered up just makes one click. and no other sound. Connecting to different PSU's gives the same result. Is it dead? Or stuck? If stuck, is there anything I can do to help make this drive spin up? If not could you recommend an equivalent drive. The activity light from the controller board the drive is connected to light often as it is trying to access the drive, so I think the controller is still ok.
Thanks
Thanks
