Arkady
Hello,
I have a HeadStart Vendex TURBO-888-XT and i don't have the switch settings of the motherboard.
It has got a weird internal layout. It has got a kind of passive backplane with 1 serial and 1 parallel port, a RTC and a floppy controller onboard.
Plugged into the 8bit ISA connectors, there are two daughter cards: one with the CPU, memory, etc... and another one with the video, memory expansion, bus mouse connector and two game ports.
Onto the passive backplane, there is a DIP switch (8 switches) and another one (8 switches) onto the CPU daughter card.
It's the same layout than the Packard Bell PB88. See below:
http://museum.ttrk.ee/th99/m/P-R/31492.htm
But the dip switch is absent onto the passive backplane of the Packard Bell PB88. I need to know the settings for this DIP switch. If someone has got this computer, could you help me, please.
The battery has leaked and i will have to fix it. I already cleaned it. The computer checks the memory, but it fails reading the floppy disks. The floppy disk heads of the two drives don't move during booting and it only try to read the drive B (the drive that is plugged to the second connector). I fear the onboard floppy controller has been damaged by the leaking battery.
Thank you.
Thank you.
