Anonymous Coward
I am interested in switching out the CPU and crystal in my IBM AT Type 2 motherboard. However, I am worried about the effects of running my board at frequencies higher than it's rated for (8MHz). I have heard of people running their AT and XT/286 motherboards as high as 33MHz?!?!??! Though when I last looked on the internets I couldn't find any information available regarding people tinkering with their ATs. Here is what I know so far:
a) If you wish to run your AT beyond the rated frequency, you will need to replace the ROM BIOS chips as they have built-in capabilities to detect CPU speed and will not allow the system to boot in this situation. In order to address this problem I have replaced my IBM ROM BIOS chips with some nice Phoenix ones.
b) The ISA frequency is fixed by a separate clock crystal, so altering the CPU speed will not cause any problems with installed adapters.
c) Changing the CPU crystal WILL affect operating frequencies of main system memory and all other components on the motherboard. i.e. the big mess of TTL chips that make up the "chipset"
Here is my desired configuation:
I am intending to upgrade my system with a 40MHz clock crystal and a Harris 80286 CPU rated at 20MHz. If everything works well, I may run with my Intel 80287XL. Since the FPU runs at only 2/3 the CPU, I am guessing it should work fine. Intel claims the 287XL operates at upto 12MHz, but it can probably go higher since the rating has more to do with the fact that Intel only produced 286s up to 12MHz than anything. I have also replaced the 150ns chips on the motherboard with 120ns chips. I may have some 100ns chips around, but I'll have to check again.
My question:
Are there any people in here that have tried to accomplish something similar with their AT type2 (319 or 339) systems? Will my components allow me to do what I wish to accomplish, or am I making a really terrible mistake? I don't want to break anything.
Additionally, I have already tried installing a Make-It-486 onto this computer, and have had limited success. The system seems to work fine, except it doesn't seem to want to reboot. Does anyone know what the reason for this might be?
My question:
