pcdata76
Hello everybody,
After reading the threads which are explaining the methodology of adding memory into UMB area and using it to load device drivers, I decided to build a simple memory card to use in my 5155, Turbo XT and PS/2 model-30 computers. Actually, I’ve decided to buy Lotech’s 1 MB RAM card PCB first, but then realized that they don’t provide shipping option to my country and decided to design a circuit having in similar concept with Lotech’s board.
I also made some design changes according to my needs, which are:
1- I used only one 512 kB SRAM chip since all my computers have at least 512k of memory.
2- Instead of 64k blocks, memory can be enabled or disabled in 32kB blocks (to be able to use possible empty spaces especially in A, B and C region).
3- Smaller design to be able to keep the card in slot without the need of slot bracket.
Since I wanted to source the components from local suppliers, had to buy some of the chips in SMD and some others in through hole package. I also couldn’t source 74LS05 open collector inverter so I’ve used 74HCT04 inverter instead, omitting the pull-up resistor.
You can find the schematic and PCB layout from the following links (sorry about the complexity of the schematic, I didn’t used labels but direct wiring):
http://i1376.photobucket.com/albums/ah14/pcdata76/Vintage PC/RAMCARD PCB_zpsz60ysbes.png
http://i1376.photobucket.com/albums/ah14/pcdata76/Vintage PC/RAMCARD SCHEMATIC_zpse0jnfeu2.png
And it comes to the story:
I’ve produced the pcb (using cnc engraving machine), soldered components and checked for possible shorts and continuity, everything seems to be OK.
To test the functionality of the card, first I installed it to a slot except slot 8 of 5155. This computer had 256k on board and 384k on AST 6packplus, total 640 k of memory. I reduced the memory on the AST to 256k, and set the switches on my card 8000 to 9FFF ON, rest OFF, powered the computer ON expecting a memory count till 640 kB, but finished at 512 with no errors on the screen, so something was wrong.
Then, I intentionally turned switches ON for A, B and F ranges one by one at each retry and saw that the computer didn’t boot as I expected due to the address conflicts. So I understand that the logic circuit on the card was (at least partially) operating. If I remove the SRAM chip, computer behaves like card was not installed independent of the position of the switches, as expected.
I exchanged the SRAM chip and 74HCT30’s (as these were the only through hole components installed on a socket) with different ones of the same model, but did nothing. I didn’t touch SMD IC’s yet as I don’t have hot air station for easier removal.
I’ve done some more test as follows:
-Enabling all 384k on AST and enabling 8000h-87FFh switch on the board: Memory counts till 512k and throws an error.
-Enabling all 384k on AST and enabling 8800h-8FFFh switch on the board: Memory counts till 546k and throws an error.
continued to test in this sequence till 9FFF and saw that memory count is increased 32k at each step as expected.
After, I only enabled D and E range and check for possible umbs with no luck :/ Then, I’ve made a last test in slot8 of the 5155 by enabling slot8 jumper and everything was the same.
I've decided to test the card in PS/2 model 30 with 640k onboard memory. If I enable switches of 8 and 9 ranges, it gives parity error as expected. If I enable D and E ranges, I couldn’t managed to get umbs.
PS: I’ve used both original and Krille’s modded versions of USE!UMBS.SYS
Anybody has a comment about the source of the problem? Did I miss something do something wrong? Is there any obvious error in the circuit design or the layout?
Thank you for your help,
Onur
Onur
