paperinik77pk
Hi all,
I just completed to restore an IBM 5160 XT, repairing the motherboard, cleaning the floppy drive, putting a 130W power supply and fitting all original IBM cards in it.
It started as a 068 model (256kb, MDA, one 360k FDD and IBM 5151) and has been modified to be a 086 submodel (256kb, CGA, one 360k FDD and IBM 5153, plus the Original ST412 disk i got in the meantime). MDA and 5151 will be part of my 5150 project in the future.
The ST412 disk NEVER worked, I found it in a flea market and it is aesthetically nice. I've the original Xebec controller, but since the disk is not turning at all, obviously I cannot get it to work.
So I kept the front panel of the ST412 and I thought to add an XT-CF (assembled by Pearce, rev2 - smallest version), connecting the panel led to the led connector on the board just to keep the "original" HDD blinking light).
XT-CF works fine on my Olivetti M24, it is fitted with a 16MB CF (fdisked to 10MB as the ST412), it is updated to R580 Bios...but...
...the XT does not detectit at all during POST. It performs the floppy seek, then it goes straight to Basic.
I was expecting the XTIDE menu as usual...but NOTHING. I removed all cards keeping CGA card only.
I tried to boot a floppy with xtidecfg.com in order to see if bios can be loaded by eeprom. NOTHING again.
I changed the starting address flashing an already modified bios (567 - CC00h), I tried to modify the I/O port from 300 to 280/290/310/320/330...no results.
At this point I'm beginning to get a bit confused.
I searched a bit on Internet, on this forum...but it seems the main issues happen when the XT-IDE bios is already detected (MBR - conflicting addresses and so on)
Dou you have some suggestions (even a link to an existing thread, so we can close this one)?
Thank you in advance!
Davide
Davide
