Hello, i have Miniscribe 2012 hard drive connected ONLY to power supply without any data cables connected. Disk LED have recurring blinking, there is video below. Any ideas?
https://youtu.be/3G5wnVBDRdI
In some Miniscribe manuals, the blinking error codes for the drive are explained.
For example, look at the bottom of the manual for the M8425S, at [here].
If (repeat: if) it shares the same error codes as your drive, then the pattern is 1000, which equates to code 8.
