Trixter
It is becoming very hard to find an actual 6300-branded or M24-branded mouse. Luckily, the 6300/M24 mouse is actually a Logitech OEM mouse, specifically model P7-3F, which shows up on ebay from time to time, and works just fine. However, that exact model was shipped with three connectors: 9-pin male, 9-pin female, and 10-pin "bus mouse" connector. You can see examples of all three here:
9-pin male: https://www.ebay.com/itm/Vintage-Logitech-model-P7-3f-Three-Button-Serial-Mouse-/122734865051
9-pin female: https://www.ebay.com/itm/Logitech-serial-mouse-vintage-P7-3F-9F-non-working-/192338776379
bus connector: https://www.ebay.com/itm/Logitech-bus-mouse-with-8-bit-isa-card-vintage-P7-3F-/192338646525
For the record, the correct connector you want to use with a 6300/M24 is the 9-pin male connector. The mouse port on the keyboard is 9-pin female.
While the 6300/M24 house has two buttons, the Logitech equivalent has three buttons. I don't recall if the middle button is functional when connected, but it isn't cause for concern.
Hope this helps someone in the future...
