?setup XTIDE v4 in Amiga 2000 w8086 card
Towmater
I've added an XTIDE rev 4 card to an Amiga 2K, but have no idea what to set all 16 dip switches to for this config, and Google has failed me. Is there any guidance you can give? What I've found so far is that the ROM address is fine at the default of D000, but I've no idea what IRQ to use, and the XTIDE came with no instructions. Searching turns up mostly results for rev two of the board, and almost nothing for rev 4.
Thanks for that, i gather from this that the rev 3 instructions and rev 4 boards are essentially the same, Glitchworks could probably update their instructions to reflect this and save some confusion.
Now I'm wondering whether the rom included with the Glitchwork kit was programmed. Is there a message visible on start-up?
Hi there :) Working on the manual, life's busy at the moment.
If you bought the parts kit, the EEPROM is not programmed. If you bought a fully assembled+tested board, then it is programmed. The card can self-program using the XT-IDE Universal BIOS configuration program.
Since I can't seem to boot the Amiga from the floppy drive (or, actually, it is a Gotek 720KB version drive), in order to program the EEPROM, is it instead possible to replace the EEPROM with a simple swap using a 27c64 pre-programmed with the rom?
I can read from the Gotek, just not boot, so I will perhaps be able to setup the compact flash in a 90's ms-dos rig once the XTIDE is running.
Yeah, a 2764 or 27256 will work fine. Make sure that the ROM image has the proper checksum generated at the end of it. The BIN files you download for the XUB are unconfigured and do not have the checksum (the configuration tool generates it). If you run into a hard time with the checksum, let me know and I can dump a configured ROM.
