Jackson
This originally came with an RLL controller. I was told to throw the hard drive out before buying it due to personal data issues. Swap the Turbo MGP with a real IBM CGA card, add on a parallel port, give it an SCSI drive, and uh, well.... tada? It looks very mismatched. The more progress furthers, the more I'll post pictures.
What's weird about this machine is that while it had a dedicated high density drive controller, drive 1 was jumpered to "1.44M" while the drive was actually 720K! This meant that the drive always had constant stability issues due to reading at an unreliable data rate; there are less issues now when I corrected the jumpers. However, often from time to time, the first cylinder still gets corrupted. Not sure if it's my only white 720K diskette that's being unstable by any means, DOS, or the drive just, well..... hating it.
If you're going to ask me about the AT&T 6300, that's still a work in progress I need to find the schematics for the color monitor to see what happened to my beloved monitor.
