KLund1
Well I though I could do it but I guess I think my skills are better then they actually are!
I wanted to replace the 8080 on a XT board I recently got with a new version. I used a IC puller, but it would not move. I used a small flathead to loosen each end. But the plastic of the socket just crumbled under the slight pressure. I pulled out the cpu, and out came many of the pin holders, and some plastic. Great! the socket needs to be replaced. NO problem, I thought, I've done this many times on my Atari 8-bity equipment. I reheated each pin to reflow the solder. Then used a solder sucker to remove the old solder. The socket parts came out without much trouble. I then used some solder braid to clean up the holes.
I put in a new socket, and the proceeded to solder it in. I looked things over with a magnifying glass and all seemed to look ok. I removed a couple small solder slivers. Ran a small flathead between my solder points just be sure. Then cleaned up with some ISO and a toothbrush. Put things back together, CPU oriented correctly, psu, video card, and booted to test. NOTHING. It was working before I messed with it. recheck, test check again, test, nothing. I think I killed it with my soldering skills.
Is there anyone in the CA south SF Bay Area that might be willing to take a look?
