eight088
Hi!
I recently acquired this beauty and trying to get it running. I have a boot disk which I've tried in another machine which works (well it will boot up but halt when it knows it's not a sharp pc) and also have a known working dos 6.22 disk. Some people suggest the machine isn't capable of running 6.22 so I'll focus on trying to get it to work with the sharp boot disk which has dos 2.11
I think it might just be the heads on the fdd are dirty and might need a clean, so tried pulling the machine apart but couldn't quite get it fully apart. Felt like I was missing something when pulling it apart as the RH side (looking from the rear) wouldn't slide out and felt like I was going to break something if I kept forcing it.
One thing I did notice with it though when I had the back cover off was that on the back of the board there's a socket for a fdd but no cable plugged in it. Is it possible the drive has been unplugged and cable removed for some reason?
Other than that the machine powers on, the hdd spins up (which doesnt seem to work atm but will work on that once I get it booted on the fdd) and the display looks fantastic. So if anyone knows if the fdd is meant to be plugged into the rear of the machine or if it plugs into another port (I realise this is probably a silly question but I'm wondering this because I cant see if there's another cable going elsewhere from the fdd) or if someone knows how to pull the guts out of the case I'd be very appreciative.
Cheers!
Cheers!
